das gibts alles schon fertig - also warum das rad neu erfinden?
der dutton schwimm kit kar umbau auf samurai basis benutzt den nebenantrieb für die schiffschrauben.
http://www.amphijeep.biz/
bezugsadresse:
AMPHIBIOUS CARS LTD
Littlehampton Marina tel 01903 721139
Littlehampton
info@amphijeep.biz
West Sussex amphijeep.biz
BN17 5DS
ENGLAND
PTO for Suzuki SJ410/413/419 Samurai/Sierra/Gypsy/Potohar/Katana
Manufactured in Japan/Spain/India/Pakistan
We have been using our own manufactured PTO on the Dutton/Amphijeep range of amphibious cars since 2000; it is designed to transmit the full 65 bhp @ 5000 rpm
The conversion consists of extending the transfer box input shaft with drive shaft grade steel and drilling out the transfer box end casing to 23mm dia. There are 4 off M8 pre-tapped holes around this end casing suitable for attaching brackets etc
DIMENSIONS: -
Shaft 22mm dia x 65mm long from rear face of bearing to spigot
Keyway 6mm wide x 3mm deep x 23mm long
Spigot 15mm dia x 25mm long, machined finish to run in bush. This can be cut off if not required
The standard Suzuki rear end bearing must be the type fitted with double rubber oil seals (2RS), if your bearing is a plain ball bearing without seals it must be replaced.
If you are interested in a drive shaft/dog clutch assembly as per our amphibious set up please ask
ORDER: -
Modify input shaft and supply 6mm key £78.00
2RS double seal rear end bearing with 2 rubber oil seals £14.80
Carriage UK £8.50
UK sales add 17.5% vat
