von WOLFERINES » Fr, 20 Okt 2006, 20:00
K.A.D. driveshafts feature greaseable 1/2-ton pickup U-joints for super strength and durability. The yokes are constructed to accommodate high angle applications as with tall lifts or Zuks with lots of articulation. Yokes bolt right up to your Samurai flanges and do not require any adaptors or spacers. Tubing is an indestructible .25" DOM tube..... they cannot and will not bend nor twist. The best thing though is the slip yoke.... An unbelievable 10" of slip yoke on the K.A.D. driveshafts means they'll work for you with a 3" lift on up to 14" of suspension lift!!! Perfect for vehicles with BIG articulation that require alot of spline movement. If you're been searching for a new shaft for your ride, search no further. K.A.D. driveshafts are built local for our shop in Utah and far exceed the quality of lookalikes. K.A.D.'s come with a factory warranty
Kosten $ 299.- stuck
weiß leider nicht wie man bild einfugt sonst hatte ich auch bild dazu.
